Hoping to find a good boat mechanic around Woodstock GA area. I bought this boat 5 weeks ago and been on the water 4 times. Been towed in 3x. This totally sucks, as I'm a first time boat owner. First couple of issues was the boat would just die, like you pulled the kill switch. I trouble shot that the keypad was bad, replaced it and the problem was solved. (I held in the "Start" button and it ran fine, so no rocket science there).
Next issue: engine coughed and sputtered and died. I drained the FCC in case of water contamination, and it fired up. Decided not to tempt fate and brought it home to change the fuel filter.
After changing the filters, turning on the power, it wouldn't fill the FCC, but you could feel the pump energize. I filled the FCC with gas and it fired up.
Dropped it in the water and she idled fine for about 10 minutes, and as my son and I were leaving the marina, she died again; cough, sputter, dead.
I take it to the Nautique certified mechanic and gave him a brand new high pressure fuel pump and asked him to "fix it, I'm done screwing with it." He replaced the pump and informed me yesterday that did not solve the problem. Next thing they want to try is the low pressure pump.
I hope this fixes it, because I'm running out of patience, money, and warm weather!
Any thoughts?
Any thoughts?
