This job has been fighting me for weeks now. Just bought the boat a few months ago (2012 SAN) and the transmission cooler went out which got water in the transmission. It started slipping before I caught it. Decided to upgrade from the 40 series to the 80 series instead of rebuilding. Since then It's been one thing after the other. It took weeks to get the transmission due to the Pandemic. The prop was stuck on the shaft when I went to take it off. The previous owners must have never taken off, because it fought me. Even heat wouldn't make it pop off. I ended up buying one of the ACME C-clamp pullers (which is not easy to find in stock right now). Got the prop off finally and started on the inside. Got the transmission cooler changed out to the 12" one with no problems. When I went to remove the shaft coupler it moved about 1/4" inch and now it refuses to let go. It literally bent the puller trying to get it off. Scared to use heat due to the gas tank be in such close proximity.
1. Any ideas on how to get that coupler off? I can pull the shaft forward so the two couplers are separated, but the shaft one is still on there. I have been using a harmonic balancer puller.I thought about trying the ACME C-clamp on it, but I am not sure there is enough clearance.
2. I thought about just putting some wood blocks under the v-drive to support it and then removing it's mounting bolts to slide it back enough to get the transmission out. Not sure if this would work and I am kind of afraid that I am going to mess up the shaft or the strut. Any thoughts on this approach or has some done this approach.
I am open to any advice on this swap. I have worked on a lot of straight shafts, but this is my first v-drive. I really didn't think it would be that bad and if it wasn't for the shaft components I don't think it would be.
Any one with experience swapping a transmission out that had a v-drive I would love some advice or tips. Anything else I need to worry about? I have been taking pictures with the hopes of uploading them in the end to assist anyone else that does it in the future.
