Two issues with my "new" 95 SN with a 351 Ford GT-40 PCM.
1) Tachometer reads accurate about 75% of the time, but 25% of the time it reads high...as in about 1,000 RPM high. Would this be a ground issue? Follow the wires back to where? It doesn't bounce...just reads high. For example normally MPH is about 2-3 less than RPM. When it's off, the tach may show 3,000 RPM though I'm pulling a trick skier at 16 mph. Next day, it might be fine.
2) I have a fuel drip from the assembly coming out of the fuel pump on the engine. The connectors are crammed into a small area but I'm certain the leak is from the connections, not the pump itself. Is there a flex wire I could use instead of this mess?
