2014 G23 LINC 2.0 screen problems
  • c640947
    • Jul 2013
    • 112
    • Badin Lake, NC
    • 2021 Nautique G23 Paragon ///// 2016 Mastercraft ProStar with tower
    Started up my boat a few days ago to this fun on the screen:
Name:	2020-07-28 19.05.57 (Medium).jpg
    I appears either the connection or the screen may be bad. Have restarted a few times and the same issues exist and aren't moving around on the screen. No functionality is affected, just the display. Anyone had this or any suggestions? A new screen ain't cheap to trying to see if there is a fix for it.
    The point out specifics:
    1. Some weird dot.
    2. a line in the screen, now there is a second one below that
    3. more lines that obscure the bottom of the screen
Name:	2020-07-28 18.34.04-1 (Medium).jpg
    Current:
    2016 Mastercraft Prostar with tower
    Previous:
    2014 Super Air Nautique G23 XR550 / EZ Loader trailer with custom Electric over Hydraulic brakes
    1996 Sylvan Special Edition 24" pontoon boat
    2006 Mastercraft X2
    1995 Mastercraft ProStar 190 with new dimension tower
  • bturner
    • Jun 2019
    • 1658
    • MI
    • 2016 200 Sport Nautique
    Let's hope for a bad or dirty connection or possibly low voltage?
    In TVs lines like these are typically caused by bad row driver or row electrode but can also be the result of software issues or loose, broken or dirty cables/connectors. The first step I would take would be kill the power completely by removing the connections to the battery to see if that will completely reset the system. Next would be to inspect and clean everything going to/from the screen to see if you can fix it with the cheap stupid stuff.
    With all the other weird stuff going on I'd be leaning more towards software or a bad connection somewhere.
    • c640947
      • Jul 2013
      • 112
      • Badin Lake, NC
      OK is turning off the perko switch enough or you think full battery disconnect is needed? Thanks in advance.
      Current:
      Previous:
      2006 Mastercraft X2
      • bturner
        • Jun 2019
        • 1658
        • MI
        You know turning off at the Perko should be fine but when I get into stuff like this I take the movie Aliens, "nuke it from orbit. It's the only way to be sure" approach and disconnect the batteries. That way you know there's no power and if a reset is going to occur this would be the best way to ensure that. Then prepare yourself to lay on your back under the dash for a couple hours for phase 2.
        • robertsmcfarland
          • Oct 2004
          • 544
          • Hyco
          • 2014 g23 550
          hey I feel the pain my screen started doing that about a year before it went completely blank .I tried reaching out to see if there was any fix... there is on a non screen issue, but a screen issue there is not .. try white lake some times the factory has rebuilt ones that didn't have a screen issue that are a little cheaper.. then new ones...I was not lucky they had none all winter so I was about to bite the bullet when jeff came to the rescue he had a used demo that he had in his garage which we agree on price ..end of story...someone posted years ago when CC stared using screens this would happen and now it is,, closed to 5'000 for anew one ouch....
          2013 G23 super air
          2010 230 super air
          2009 220 super air
          2008 210 super air
          2005 210 super air
          2003 calabria pro air
          • c640947
            • Jul 2013
            • 112
            • Badin Lake, NC
            Its hard to see in this picture but when I powered the boat down and removed the screen, the circle and the lines are still present, which tells me something is wrong with the hardware and it will need to be replaced. (I wiped it off but in the picture it showed as with some smudges.)
            If anyone knows of a screen available let me know. I cleaned and checked all the connections just in case as well but that did not solve it.
            Andrew
Name:	2020-08-03 16.19.00 (Medium).jpg
            Current:
            Previous:
            2006 Mastercraft X2
              • 16728
              • 2026 SAN G23 PNE 1985 Sea Nautique 1980 Twin-Engine Fish Nautique
              All I can suggest is buying from NautiqueParts and using our discount code (PND) to save almost $400. That screen is still crazy expensive though.
              https://www.nautiqueparts.com/product/linc-display/
              • Stevemo14
                • Apr 2019
                • 691
                • Columbus, OH
                I have a line on a working used one if you are interested. should be at least 1/2 the cost of new. If you are interested let me know.
                • bturner
                  • Jun 2019
                  • 1658
                  • MI
                  This was one of my concerns when I was looking for a new boat and I have commented on this topic several times here and on the MC site as well. $5K is absolutely ridiculous and highway robbery. You can buy a complete top of the line laptop from the most expensive manufacture for half that. And BTW this isn't just a Nautique thing either, you can find the same type posts on any of the top manufactures sites. I mean when you look at this you're talking new engine territory in cost for the replacement.
                  It would be interesting to see who made the original and see if they have a suitable replacement that could be retro fitted. Believe me Medallion or Teleflex didn't design these themselves so those parts had to come from somewhere. When you pull it apart see if you can find any manufacture's part numbers or names on the old display. There's some really talented shops out there that may be interested in the repair business once they see the gold in them there hills.
                  • c640947
                    • Jul 2013
                    • 112
                    • Badin Lake, NC
                    Many thanks to Stevemo14 for a screen. Exact same model number but when I swap them out the boat does not turn on. I swapped the media card too (but I think that shouldnt matter as it should just be the map function) but still nothing. The key pad works but nothing seems to "boot up" - the ballast pumps dont prime and nothing seems to happen. Anyone aware of something special that needs to happen to swap screens besides just plug the new one in?
                    Maybe the second screen is dead (its a used screen) but seems like the boat would at least go through the startup sequence, so makes me think I am missing a step.
                    Current:
                    Previous:
                    2006 Mastercraft X2
                    • MTCscreens
                      • Jan 2022
                      • 3
                      • Keywaydin
                      • Naples FL
                      • SN
                      Hey all- just to update the community, we can now repair these black spot or line displays on the Nautique linc systems. Here is another forum member that was restored a few weeks ago: the customer said they saved several thousand dollars compared to buying a new display.
                      https://www.instagram.com/reel/DIKZc...RlODBiNWFlZA==
                      • Cadesun
                        • Aug 2007
                        • 108
                        • Lake Geneva, WI
                        • 2013 SAN 210 TE,,, 1998 Super Sport - sold
                        Just a quick add on this topic... my screen went out and was replaced last year for the above mentioned highway robbery price. The dealer never reinstalled my map card, I complained and asked them to reinstall over the winter. I was informed this spring that the connection has changed and my map card would not work with the newly-installed LINC screen and I would need to pay an additional $750 for a dongle and harness for the maps to work again. So not only do these screens die, but your maps die with them.
                        We are currently in the market for a new boat and this does not help Nautique's case!
