Hey experts,
first post here after owning my 2018 Ski Nautique 200 since February now.
Used to be a Malibu guy for almost two decades (had 3 different Responses and loved all of them).
But at some point it was time to upgrade. I couldn’t get myself to like the looks of the new TXI, so went with a 200 instead.
Got a fantastic deal on a low hour closed bow 200 Team with the ZR4 engine and we absolutely love it!
I have a question concerning the auto bilge burst feature...
The boat sits on a covered lift when not in use.
Obviously in my case there’s no need for the bilge pumps to check every couple minutes for water in the bilge.
(I have the dripless shaft seal and there’s never any water inside the bilge anyway.)
To save the battery from draining, I always turn the main power switch off to disable the auto bilge function.
Problem is - when powered off, I keep loosing some ZerOff settings, like the timer beep after each slalom pass.
It’s pretty annoying to set the timer every time I turn the main power on to use the boat.
Is there any way to disable the auto-bilge burst function, so that I can just leave the main power switched on when I’m not using the boat?
Thanks for any feedback/insight on this!
Cheers,
David
Cheers,
David
