I just purchased a 98 nautique, relatively low hours, and in nearly perfect condition. The gel coat has only a few very superficial scratches on the bottom of the Hull from trailer bunks, otherwise no defects whatsoever. The interior has no sun damage...overall very nice boat. I noticed on our first trip to the lake that it lists slightly right at rest. Maybe 1/2 inch to an inch lower on the right vs left. The bilge is clean, no water lines on the block or anywhere else I can see. I had to remove the right pitot tube to replace, no water came out. I know these boats are all composite, closed cell foam between stringers. Is there somewhere water could be hiding that I need to look first? Or is there some other weight and balance issue that could be causing this? I appreciate any help you guys can offer!
