SV211 Walkthrough Latch Question
  • Wildcat04
    • Jun 2017
    • 43
    • Wichita, KS
    • 1997 Air Natique
    Could someone shoe me a picture of the latch (boat side, not hatch side) of their SV211? My hatch has a good latch but there is nothing for it to catch on the boat side. I moved the lock nut and latch all the way down the post and it “kinda of” catches on the fiberglass but it just doesn’t seem right. I’m wondering if there is supposed to be a metal catch there.
    Just boat the boat last fall...2004.
    Thanks in advance.
  • SkiTower
    • 2172
    • Clayton, NC
    Don’t have access to a picture but it does only catch on the fiberglass.
    2007 SV211 SE
    Tow Vehicle 2019 Tundra
    Dealer: www.Whitelake.com
    • Jsfrei05
      • Jun 2018
      • 3
      • Boise idaho
      • 2007 SV211
      did you come up with solution? i have same issue. it latches but needs improved
      • MN Ryan
        • Aug 2020
        • 1398
        • Maple Grove, MN
        • 2007 SV-211 TE
        I have an '07 but will see if I can grab photos this afternoon.
        Sent from my SM-G970U using Tapatalk
        • Jsfrei05
          • Jun 2018
          • 3
          • Boise idaho
          • 2007 SV211
          i have 07 as well. inguess just tighten the bolts underneath.
          • Jsfrei05
            • Jun 2018
            • 3
            • Boise idaho
            • 2007 SV211
            here is where latch catches
            • MN Ryan
              • Aug 2020
              • 1398
              • Maple Grove, MN
              • 2007 SV-211 TE
              Here's my catch and my latch. Anyone have a source for the rubber bumpers on the walk-through life? I could use a few new ones.
              • MN Ryan
                • Aug 2020
                • 1398
                • Maple Grove, MN
                • 2007 SV-211 TE
                Good looking 211, Jsfrei05! Mine:
                • yeahbuoy
                  • Mar 2020
                  • 40
                  • Atlanta, Georgia
                  • 2005 Air Nautique 211 TE
                  My 2005 SV-211 is similar - the walk-through latch just catches on the underside edge of the fiberglass, and the fiberglass is worn as shown in the pics others have provided. If the nuts on the latch are not perfectly adjusted, the latch doesn't hold. Mine is sensitive enough that it will only latch when turned counter-clockwise, not clockwise. I expect to address that gremlin soon by attaching an angled / rolled piece of metal along that edge to give a more substantial surface for the latch to catch. Should also end the wear on the fiberglass edge.
