Hi guys,
New to the forum and I'm coming in needing some opinions.
I have a 2001 Nautique with the 351W GT-40 motor with 300 hrs on it and I'm having some engine issues.
The story is that I bought the boat used, took it out and immediately noticed that it was running rough. Towed the boat home and figured out that it was a burnt valve so I had the head/ valve seats re-machined, and put it back in but now I am getting some excessive lifter noise that is not going away. It's coming from just one of the lifters and I'm wondering what the best thing to do is. I had a mechanic friend help me with the head and he's unavailable so I'm trying to diagnose/ fix this on my own.
The symptoms are as follows:
Tap is present from start up and is only audible at low RPM especially at idle. The noise goes away when any load is placed on the motor beyond just having the boat in gear then returns when I put the boat in neutral or the RPM drops down. The motor did not have this noise prior to the rebuild on the head. Anyone have any ideas? I was going to get in there and see if the push rod is bent but does anybody have any tricks to get that lifter to pump back up? I've tried liquimoly in the oil which helped a little but I'm concerned that if I leave it like this that I'll eventually bend a push rod or even flatten out the cam lobes.
Running SAE 40 Valvoline Racing Oil
Any suggestions or insight would be appreciated!
