I'm looking for some ignition system help on a 1995 Sport Nautique with Ford 351. I have done quite a bit of troubleshooting and think I have narrowed it down but looking for other experience to make sure i'm on the right track. I just changed the spark plugs, had the boat lowered on the lift the boat fired up and was running at a high idle for about 3-4 minutes and it sounded good. When I moved the throttle back to center the engine cut off and would not restart. It turns over but there is no ignition. I have pulled the wire off of the coil and I can see a spark both at the coil and at the end of the wire that would plug into the distributor cap. I do not have any spark at the plug and I can't see any sparking at the distributor cap on the output side going to the plugs. The boat has a Mallory YCM 544 CV distributor. Since I see spark at the coil I assume the coil is good. I assume I need to replace the rotor and cap. Could the coil still be bad even though i'm seeing spark? Is there anything else it could be?
Thank you in advance.
