Error code is: DTC 606 Microprocessor failure - COP Source 0, SPN 629, FMI 31
Boat is a 2012 super air nautique 210 with PCM EX343 5.7L
My research shows this is an internal ECM issue. Are there any other causes? Can I reset this myself?
The boat appears to run normally, is there a risk in running with this code?
The transmission was recently replaced, so the engine was pulled by the dealer. One of my amps showed a "protection mode" red light which I traced to the main amp ground wire not being reconnected to the engine stud. Soooo....I'm wondering if something else could have been missed when the engine was reinstalled.
Any ideas of what to check/test?
thanks in advance.
thanks in advance.
