Background: Was going through the engine two years ago when I picked this boat up. Notice throttle cable was loose on the tree where a brass adjust bolt was (in pic and don't know tech name) I saw it was loose, tried to screw it back into brass....wouldn't. So I left it as is and did all my other work on the engine and have used it as is for two years.
Now: I decide to do some work this spring.....and being on lockdown I thought it would give be something to do. When I sort of took it apart, I realized I think it is supposed to be this way. I just don't like how loose it is, as well as the throttle brass bar it threads through.
Is this correct, or broken, or what ?
And, now that I have tweaked it, whats the best way to tune it correctly this spring when I fake lake run it?
thank you
D
thank you
D
