Let me guess: The day you had it in the water was cool and the humidity was low. The water was probably on the cool side as well. Under these conditions, you'll see the steam from the exhaust. Any boat without a surf pipe will show steam under the right conditions.
If all of your gauges are good, the engine is cooling and all of the fluids are good then you're fine. Get it out on the lake and run it up to speed. See how it does. I bet it's just fine.
-Charles
-Charles
