I have a 2011 SAN 210 TE with the original Linc system on it. Last fall I received a SNP 84 FMI 8 code while out on the water. Upon further investigation I noticed I was not connecting to any gps satellites which caused mph to display zero on the dash. After checking the wiring under the dash and not seeing anything out of place I decided the r2 antenna must have died and needed replacing. I ordered the GPS ANTENNA FOR V-DRVIES W/ LINC R2 ANTENNA from nautiqueparts and installed it this spring. I now have connection to the gps satellites however I still do not get any speed readings on the dash. Location and speed will display on the gps map screen but zero off and the main cluster continue to show 0.0 mph. Has anyone else run into a similar issue? Is there a different R2 antenna for the original Linc system? The only other thing I can think of is that there is a software compatibility issue, Linc is currently running software 6.1.105 and boot loader 2.2.26. With New York State shut down for COVID-19 I’ve been unable to get a hold of my local dealer, any help or input is greatly appreciated.
Have you called NautiqueParts? I bet they can help you.Please do not PM me directly asking for advice on how to repair your boat. While I would love to help everyone, I simply do not have time to respond to all of the inquiries. Please post your questions on the forum, so that all of our members have a chance to answer.
Hey Jeff, thanks for the recommendation. I've sent an email to their support team just waiting for a response. Thought I would post here while waiting to see if anyone else may have ran into a similar issue. I will update the thread if a solution is found through NautiqueParts.
Please let us know what the fix is. Many of us are running boats with Linc 1 and information on any possible issues we may experience is always helpful.
Just to close the topic for anyone with a Linc 1 system, this issue was with compatibility of the antenna. After speaking with NautiqueParts and ZeroOff it was determined that NautiqueParts was delivered incorrect stock of 3 Event Antennas instead of the wake version they normally sell. ZeroOff and NautiqueParts are currently on working with me to resolve the issue as quick as possible. I would also like to mention that both companies have superior costumer service and have been very easy to deal with to figure out the root cause and remedy for this issue.
