This is my first post. I was wondering if anyone could add some insight on best practice to perform a DIY fiberglass repair.
I purchased a 1990 Ski Nautique right at a year ago. I spent the spring and most of the summer rewiring the dash and a multitude of other things to seemingly get it water worthy, so I really only had it on the water a hand full of times last year. I noticed the bilge filling up with water... not a terrible amount, but more than what I thought was reasonable. I didn't want to leave it on the water overnight, as I wasn't sure if it would be floating in the morning. Now that the weather has broke, I filled the bilge with water to see where it might leak out, and located some cracks at the prop shaft strut. Photos are attached.
Based on some internet research, my plan is to grind out the cracks from the bilge, and do the bulk of the repair from the top side. I was thinking of using West System epoxy, but am unsure on whether to use mat or some other fabric, or some specific combination of the two, or how thick to make the repair. I was then going to do a thin repair on the bottom side, again with West System epoxy, and some sort of filler, and the touch up the gelcoat.
Does the above sound reasonable? Should I consider a poly resin, especially on the underside? Any pointers on glass material to use? All help and information is welcomed.
Thanks,
Dan
Thanks,
Dan
