Backstory: There is mild sun damage on my new-to-me 2004 Nautique 206. Mild can be described as some oxidation and fading on the black transom with some similar fading on the vapor blue waterline stripe. The waterline striping is worse in the aft and disappears as you move forward. Overall, I'd say the fading is consistent with storage on a lift with the transom facing south. Prior to my purchase, the dealer did a buff out on the boat and removed the worst of the transom fading but it wasn't a through job, more of a 'blow and go' to improve the show-ability of the boat. I never saw exactly how bad the oxidation was.
Fast forward to now. I wanted to clean up the remaining oxidation and get the boat looking tip top. The bow area was an easy call - a simple rotary polish and wax was sufficient. For the polish, I used Meguiar's fine cut cleaner and a HF variable speed rotary polisher with a wool pad. This was followed by a wax coat. Results were great...no issues.
For the transom, I used this same approach but didn't have as good of results. There was still hazing in the black with a clear visible line where some of the safety stickers had covered the fiberglass. The vapor blue line also improved but as with the black, I could also see hazing in the line. Based on this, I decided to try a light wet sand. For wet sanding, I used a 2000 grit 3m paper with a soapy water solution and then followed this up with the same rotary buffer / Mequiars polishing compound. I was pretty cautious with the sanding...it was enough to scuff the surface and material was clearly being removed. When I polished the sanded area, I had to use more polishing compound and pressure to restore the shine. All this felt pretty normal.
The initial results on the trailer looked great. The haze was gone and i didn't see any sanding marks. However, after launching the boat and wiping it down combined with getting the boat in some different light, I wasn't as happy with the results. Specifically, there was still haze in the black although it was better than before. And there were still some areas with residual standing scratches from the 2000 grit paper. For the sanding marks, I chalk that up as being due to a less than through polish out - those areas just needed more wheel time & pressure. For the remaining haze, less clear what to do.
So...now to the questions...
1) For black surfaces that have been damaged, is it realistic to expect that I will be able to get all the haze out? From my one of my past lives working as a car detailer, I'm quite aware of the special issues that black surfaces pose.
2) Would I be better serviced to use a two stage standing process? Watching youtube vids, I see people starting a 1000 then progressing to 3000 paper. To me, 2000 felt quite aggressive and I would be hesitant to start with 1000. However, is there a clear benefit of following a 2000 with the 3000? I would expect there would be less need to use the polishing wheel with the compound...
3) How do you gauge what's 'sufficient' sanding? It's tricky to tell how much material you're removing and if you have gone deep enough. I also am keenly away that sanding is a one way door and you if you over sand you really can't go back. Now I get that gelcoat is much thicker than auto paint so there's an extra margin there. Are people just making educated guesses on the amount of sanding then polishing it out and seeing if it was sufficient? And then rinse and repeat until you are happy? I'm OK with this if that's what's really needed...it's just not really time efficient.
Any other tips or tricks that might be helpful?
Thanks in advance for the input!
