I was pulling somone on a board and making a turn under power and I felt the steering wheel jerk and then the rudder was stuck full left despite where wheel was turned, the rudder was able to be moved by hand but steering wheel is completely dead. The rudder is cable driven right? Does this sound like it needs a new steering cable ?
It is very unusual for the cable to break. Check the attachment at the rudder. It may have just come loose.
Current Boats —> 2024 Super Air Nautique G23 PARAGON -- 2018 SAN 210 TE -- 2003 Ski Nautique 196 -- 2002 Ski Nautique -- 2001 Ski Nautique -- 2000 Sport Nautique -- 2000 Nautique Super Sport -- 1998 Ski Nautique -- 1996 Ski Nautique Open Bow -- 1985 Sea Nautique 2700 (Twin-Engine, 1 of 13) -- 1981 Fish Nautique (Twin-Engine, 1 of 4) -- 1980 Fish Nautique (Twin-Engine, 1 of 4)
Former Boats —> 2023 Super Air Nautique G23 -- 2022 Super Air Nautique G23 PARAGON -- 2021 Super Air Nautique G23 -- 2021 Super Air Nautique G23 -- 2020 Super Air Nautique G23 -- 2019 Super Air Nautique G23 -- 2018 Super Air Nautique G23 -- 2017 Super Air Nautique G23 -- 2016 Super Air Nautique G23 -- 2015 Super Air Nautique G23 -- 2014 Super Air Nautique G23 -- 2014 Super Air Nautique 230 Team Edition — 2013 Super Air Nautique G23 — 2012 Super Air Nautique 210 Team Edition — 2011 Super Air Nautique 210 Team Edition — 2010 Super Air Nautique 210 Team Edition — 2008 Super Air Nautique 230 Team Edition — 2007 Air Nautique 236 Team Edition -- 2007 Air Nautique SV-211 -- 2005 SV-211 -- 2003 Super Air Nautique 210 Team Edition -- 2003 Air Nautique 226 -- 2003 Sport Nautique 216 -- 2003 Ski Nautique 196 -- 2001 Sport Nautique -- 2001 Ski Nautique -- 1999 Ski Nautique Open Bow -- 1999 Air Tique 176 -- 1998 Ski Nautique -- 1998 Ski Nautique -- 1997 Ski Nautique -- 1997 Ski Nautique -- 1994 Ski Nautique -- 1993 Barefoot Nautique -- 1983 Fish Nautique (TWIN ENGINE, 1 of 4) -- 1981 Fish Nautique (SINGLE ENGINE)
NautiqueParts.com - Roswell Marine - Phoenix Trailers - SkiSafe - PCM Marine Engines - PerfectPass - C&S Marine - OJ Propellers - WakeMakers -- Swell Wakesurf
Don’t cables have adjustment nuts on them? Maybe one of this broke loose. It would be back near where cable attaches to rudder
Not sure how Nautique does their steering has I haven't worked on the steering on one yet but every other inboard I've worked on has a clamping block just upstream of the tiller arm. If the clamping block was not tight or broke this would allow the cable to slip one direction or the other effectively creating your issue. Sine you say the cable is still attached to the tiller arm, this is the first place I would look.
Another trouble shooting test I would preform if the clamping block looks good would be to disconnect the cable from the tiller arm to see if the wheel still move the cable end in both directions. This will tell you if the cable somehow snapped internally which as Jeff states would be very rare indeed.
Yea agreed. It's a very simple system. The steering wheel has a gear on the back that meshes with a rack. The rack is attached to a cable. The end of the cable sheath is locked in an adjustment block that allows for evening out the rudder throw side-to-side. The inside cable is attached to the tiller arm on top of the rudder shaft.
You're going to have to do some fault isolation and figure out where the problem is.
-Charles
- Likes 1
