Fake a Lake
  • NicJ
    • Aug 2019
    • 36
    • Wilmington NC
    • 1998 21' sport nautique
    Fake a Lake
    Is it safe to use a fake a Lake? I believe I am covering the correct intake. But it doesn't completely cover the entire intake. I understand not rev the engine. If anyone with experience in this is reading, I would appreciate any comment or suggestions.
    thanks
  • charlesml3
    • Jan 2008
    • 2480
    • Lake Gaston, NC
    • 2022 G23
    Yes, they're perfectly fine. Most likely your garden hose will provide MORE water than the engine actually needs.
    -Charles
    • MTRBTR
      • May 2012
      • 485
      • MT
      Not true in my case. My engine sucks faster than the hose. I much prefer the bucket method. That way you can tell if your pump is working. On your boat it is very easy to pull the intake hose and put it in a bucket of water. Run the hose into the bucket. Fake a lakes scare me. I know lots of people use them but I just don’t trust them.
      2006 SV 211 (Sold)
      97 Sport Nautique (Sold)
      89 PS 190 (Sold)
      75 MFG (Sold)
      • CHassmann
        • Jul 2004
        • 520
        • Holiday Lakes, OH
        I remove the intake hose where it connects to the through hull fitting and stick the hose directly into it.
        Ski on dude!
        • Evening Shade
          • Apr 2015
          • 1295
          thanks
          I don't think I would use it if it doesn't completely cover the water intake. It will cause air and insufficient water to be drawn into the engine. I would draw water in with the intake hose from a bucket or trash can. I use a trash can because the engine will drain a 5 gallon bucket super fast.
          I got a light weight 25' corrugated plastic hose and plastic hose connector from Lowes to draw the water from the trash can.
          https://www.lowes.com/pd/STAR-Water-...ose/1000678131
          https://www.lowes.com/pd/Genova-10-P...upling/3459942
          • NicJ
            • Aug 2019
            • 36
            • Wilmington NC
            Thanks for the help!...If anyone has any pics on file, that would be cool.
            • Neptune442
              • Jan 2019
              • 256
              • Henderson, MN
ID:	596005Click image for larger version
ID:	596006Click image for larger version
              Had the same issue on my 2000 Sport. Water spewing everywhere from the fake-a-lake, and never felt comfortable using it. Cut a hole in a piece of plastic, and now it's much better. Nothing fancy, but at least there's water coming from the exhaust now with the engine at idle.
              • NicJ
                • Aug 2019
                • 36
                • Wilmington NC
                Great idea, thanks a lot! I run in brackish water and need some way to keep the engine clean. I will be getting on it in the morning. Thanks for the pics.
                • LindMark
                  • Jul 2018
                  • 34
                  • Fort Worth, Texas
                  • 2012 SAN 210TE
                  I installed a T in my water line from quickflushvalve.com to run the boat out of the water. Works good.
                  • 03SANTE
                    • Sep 2018
                    • 166
                    • PA
                    • 2003 SANTE
                    I'm in the T club...made this with help from the forum... I just put it on before winterization temporarily but you could hose clamp it after the strainer for everyday convenience. With the engine off it just spills backwards through the strainer onto the driveway. As soon as the engine is on the flow is pulled through the cooling system. For permanent use I would add a hose clamp on all 3 connections.
                    Click image for larger version  Name:	20190515_145312 - Copy.jpg Views:	0 Size:	50.9 KB ID:	598617
