2008 230 with 343 excal. about 1100 hrs, always had routine maintenance performed (dealer up to 900 hrs, and me since. Always use ethanol free fuel. Always fresh water use. About two weeks ago engine started, for the lack of a better term, 'loading up' as if it was getting too much fuel. This would cause a rough idle and a noticeable fuelly exhaust smell. I changed cap and rotor and new spark plugs were installed. (both needed it) and actually found a spark plug loose - enough that I didn't need the socket, weird. Plug porcelain looked like running a little rich across all cylinders. Boat starts up quick now but still seems like it is rich. plug cables look fine with no cracks or dryness, ends snap onto plugs well. Batteries kept on a NOCO maintainer and voltage is within normal limits.
My gut tells me it is not fuel system related but ignition related.
Anyone have any input? Thanks in advance
