Before hauling the boat across the DFW metroplex I thought I would see if any of you guys had ideas on this. 97 Supersport. Rebuilt engine last year. Had problems all summer with boat randomly not starting. Boat would be running great, starting/stopping, then key does nothing to start...no clicks. All powered accessories work fine during this time. After a wait it will fire back up. Sometimes it first happens 20 minutes in, sometimes 2 hours in.....Boat temp gauge is fine.....Wait time varies from 15 minutes to an hour + before it will restart. Hoping there is something quick and easy. It's still upper 90's and want to get out on the water some more before the temp drops too much.
The lanyard connection wouldn't cause it to not crank. My bet is the key switch or the wiring to it. Could also be the ignition breaker on the dash panel or a bad connection at the plugs between the dash and the rest of the wiring.Please do not PM me directly asking for advice on how to repair your boat. While I would love to help everyone, I simply do not have time to respond to all of the inquiries. Please post your questions on the forum, so that all of our members have a chance to answer.
Not the lanyard. Already tested everything around that. Several times out of frustration I have ripped the dash apart and put back together with no change, so I don't thinks it's wiring at the dash. Plus, if it was would the key still allow all accessories to function but do nothing with start???? Would heat cause breakers to not work then when they cool start working????? This never happens when cold. Only after its been running for a while.
