I have a 2007 SV211 PCM Excalibur 330 the motor starts and runs smooth but performance has been dropping (230 hours total). Last weekend I changed the FCC filter, apparently my boat did not come with the inline filter from the factory. The new filter did not help the performance (perfect pass is off), the engine only revs to 3400 rpm while under load, but will rev freely in neutral. I believe it is being fuel starved... there is no difference in performance when the throttle is fully on and when it is push down only 60% of the way. What would be next step to take?, (pressure gauge on fuel line - if it is low pressure) what else should I check. I keep my boat on a lake an hour and half from home, so when I get there I want to be prepared to fix whatever is wrong if possible (need to order parts to have on hand). Any advice would be great!
I did post this comment on another fuel system post, but wanted to post directly to get it out there. Taking boat to shop at this point in the season would effectively end it so would love to fix myself and get a few more outings.
Thanks, Jason
