'98 Ski Nautique, GT40
Was running fine, stopped to change skiers and wouldn't start. towed back to ramp.
Symptoms:
Turning the key produces a light beep and ignition light comes on light and fades. dash gages flicker slightly. Fuel pump does not wind up when key turned to on. Battery is fully charged. Battery terminals are clean and connections are tight. Appears no power (or very little) is reaching the engine.
Guessing there is an issue with dash ignition switch, but the faint light and clicks seem to suggest otherwise.
Any thoughts??
Thanks in advance!!
Phil
Symptoms:
Any thoughts??
Thanks in advance!!
Phil
