Hey all,
I just changed the distributor, and belts, boat (with GT40) has been running fine. However, since changing those, there's always a smell of something burning when the engine is running, perhaps rubber. Can't find exactly what or where but it's somewhere near the distributor, near the belts, waterpump side. If my nose is right, at least
I think that timing might be a little bit off; from what I read here it should be 5 degrees before TDC and the mechanic said he'd put it at 0 degrees.
Could timing being off a bit cause anything to heat up excessively..?
A friend suggested it could be the big (exhaust?) hose, from manifold to damper...
Since it started right when the distributor was changed I figured it had something to do with that, but perhaps just a coincidence and it is something else?
If that big hose, would that possibly the impeller going out? Was about to change that anyway, but what else to check?
Thanks!
Thanks!
