I have an 04 SANTE with the 330 Excalibur engine. I am having a little trouble with a hesitation AFTER taking off. Initial takeoff is fine until about 10mph. My engine hesitates until I reach about 13mph then ramps up to the preset Perfect Pass speed and then runs just fine. Does anyone have any ideas what might be causing this? I think it only does it when I have my Perfect Pass on. Any help would be greatly appreciated.
RE: 04 SANTE 330 Excalibur hesitation
I think that it is definitely a perfect pass problem.
Remove the engine cover and see if the flexible cable that tensions the throttle cable is fine.
See also if you have no speed information cuts - compare the perfect pass indicated speed with the speedometer information and make sure that you have always speed information in the perfect pass monitor.
Verify also all of the throttle cable links.
Anyway, it is very important to make sure if that happens only with perfect pass or not
