There is talk that the newer Cat engines shouldn’t be fogged. I just went from a 2009 196 pre Cat to a 2018 200 with the ZR4. I would spray the individual cylinders and then start the engine and shut it down when I see smoke.
My questions are first should I fog it at all? And second if I do fog it is what I use to do correct? Or should I not start the engine again after spraying the cylinders?
