210 with H5 Prop Upgrade.
  • zigs
    • May 2007
    • 100
    • ND
    • 2018 G21 2004 196
    I have a 2017 210 with the H5 motor, and do not think the stock prop is the best prop for my uses. We primarily surf with stock ballast full, with the wakemakers exact fit bags in place of the stock pro ballast bags, and about 250 lbs of shot bags, 100-150 in the nose, and 100 on the port side. Boat seems to run at higher RPM's then needed, and almost start to cavitate if turning, while surfing. For wakeboarding the rear is usually not 100% full with the wakemaker exact fit bags, but fairly close to stock pro ballast weight, and it has a hard time getting on plane depending on people in the boat. I talked to Acme and they said the stock 1579 is more of a ski prop, and recommended the 2079. We do not ski behind the boat so top speed is a non issue, I have a 196 for any skiing, or footing that is done. I am looking to improve surf and wakeboard performance, and hopefully lower RPM's a bit. Anyone have any experience with the 2079, on a 210 with the H5 or ZR4 motor? Did it seem like a noticeable, and worthwhile swap?
  • zigs
    • May 2007
    • 100
    • ND
    • 2018 G21 2004 196
    Up top to see if anyone has any experience with the 2079 which acme recommended or the 1433 or 1617 that wakemakers suggests for a 210. Going to order one in the next couple weeks to put on right away in the spring.
    • XBIGPUN66
      • Oct 2012
      • 470
      • Lake Mendota
      • WI
      We went with the 1617 on our 2014 210 and it works great.
      Ian S
      • jondavis08
        • May 2016
        • 369
        • Battle Creek, MI
        • 2014 SANTE 210 2003 SANTE 210-Sold
        1617, great upgrade
