2003 Correct Craft 206 Auxiliary plugs not working
  • DUG206
    • Aug 2011
    • 35
    • SAN DIMAS
    • 2003 CORRECT CRAFT 206
    I have a 2003 Correct Craft 206. it has 3 Auxiliary plugs or lighter plugs ... bow, driver seat and stern of boat none are working. I checked all fuses under dash
    and all tested to be working properly and yet no power at any of the plugs. Also at around the same time my Hatch in the stern of the boat which is operated by a
    electric switch (two switches neither work) quit working as well. Thinking possibly related. Does anyone have some insight to this issue. Does anyone have the wiring diagram
    to this model and year boat. Thanks for your help Dug
Name:	new boat Air Nautique 206.jpg
  • Skidave
    • May 2005
    • 698
    • York, PA
    There is a breaker called 'Hatch or Latch'. Make sure this is set and not tripped. I have the same boat, but have not had this issue. I looked today, and can't see the exact wires on the the latch switch or 12V socket. But it is likely they are on the same breaker.
    I asked many times for the exact wiring diagram when I purchased the boat (new). Nothing could be produced. There is some wiring diagrams on this site, but not to the detail you need.
    Sent from my SM-J320V using Tapatalk
    • DUG206
      • Aug 2011
      • 35
      • SAN DIMAS
      thanks for the response.. when you say there is a breaker called hatch or latch where might this be(engine compartment, dash, stern, etc.)? this is not a fuse it is a breaker you are describing correct? Thanks for your help...my boat is 200 miles away at my vacation home ill be there oct 20th and want to figure this issue out before the season ends..
      Thanks for any help you can provide.
      • Skidave
        • May 2005
        • 698
        • York, PA
        Driver's kick panel. That is where the breaker box is located.
        • DUG206
          • Aug 2011
          • 35
          • SAN DIMAS
          NOW its all WORKING YEAH!! Update on the My 2003 Correct Craft model 206 Auxiliary plugs and stern hatch not working. They are all working now.. This weekend continued to do trouble shooting , after removal of kick panel and testing more, i determined the ground was perfect and was missing the power at the plugs. Started following wires and found that behind the Ignition switch there are four terminals. One of the terminals had nothing connected to it.. Turns out the power source to the Auxiliary plugs and stern hatch
          had simply come unplugged from behind the ignition switch. Not sure how it came off musts have been loose for years since the connection seemed to be very firm when
          plugged back in. Thanks for you help SKIDave
