Hi, I just purchased my first Super Air Nautique. I notice that the Linc display has a button for the camera but it just shows a blue screen when I press it so I assume no camera is installed. How do you install a camera to be integrated with Linc? Thanks in advance.
Should be an rca plug where your battery switch is....
Sent from my SM-A520W using PLT Nautique mobile app
"I'm on a boat........"
Thanks. So you would need to plug in a wired go pro camera and mount it to the waketower?Originally posted by toomuchuv View PostShould be an rca plug where your battery switch is....
I do a really neat trick for a rotating camera. Use a piece of 2" ABS with a cap glued to it. Put GoPro attachment on cap. Drill a hole in one side big enough for your rope to go through. Feed the loop though and and connect to tower then place the fitting over top... You now have a swivel camera mount!
Thanks. I’m surprised they didn’t integrate a camera on the tower as an option.Originally posted by toomuchuv View Post
