Collinite wax!
  • Andy1972
    • Oct 2004
    • 128
    Collinite wax!
    Holy cow! I used Collinite wax. What’s the secret to using this stuff. 3M liquid wax goes on and comes off easily. I put collinite on, sits 10 minutes to firm up, and then spent the next 10 hours removing it! Granted it’s lasting a lot longer , but wtf
  • jimmyonthewater
    • Jul 2018
    • 5
    • Southern IN
    I never had any issues with their wax. I always use the hull cleaner first after a good was and then the liquid wax. I remember using the paste wax before and it was tough to buff off but the boat was long overdue. Are you using the liquid or paste wax?
    • srock
      • Oct 2008
      • 1108
      I love Collinite but did not experience the issues you are having.
      • Andy1972
        • Oct 2004
        • 128
        Yellow paste - it would not come off, maybe I put to much on- I don’t think so though- I’ve waxed my boat twice a year for 20 years with liquid-
        • gary s
          • Mar 2015
          • 335
          • Algonquin IL
          Never had trouble with the Collinite 925 and a foam pad. What are you using if it's yellow?
          • jimmyonthewater
            • Jul 2018
            • 5
            • Southern IN
            I think he’s referring to the 885 fleetwax paste. I have some at home that I might try out again to see what it does. I like the 925 so much that I don’t ever use the 885. IIRC the 885 says to use a damp sponge or applicator pad when applying... it’s been a while since I have read the directions. Did you use a damp sponge or pad?
            • jimmyonthewater
              • Jul 2018
              • 5
              • Southern IN
              I think he’s referring to the 885 fleetwax paste. I have some at home that I might try out again to see what it does. I like the 925 so much that I don’t ever use the 885. IIRC the 885 says to use a damp sponge or applicator pad when applying... it’s been a while since I have read the directions. Did you use a damp sponge or pad? I have never tried waxing it without using the collinite hull wash either. I’m not sure if that would make a difference.
              • Infinity
                • Sep 2017
                • 730
                • Lake Norman - Denver, NC
                • 2014 SV244 w/ ZR409
                I use the 925 Collonite paste wax a few times a year. Easy on and easy off.....something is not right if its that tough to remove. Never seen the yellow paste you are referring too tho
                • homer12
                  • Feb 2016
                  • 584
                  • Indianapolis, IN
                  • 2004 SV211 TE
                  I’m going to assume you put it on really thick if it took that long to get off. I use the paste wax.
