06 Sv211. Box located Near Drain Plug
  • DJ Arwood
    • Jun 2018
    • 29
    • Mississippi
    • 2006 SV211 Team Edition
    Trying to learn my boat. Can anyone help me identify this box is located near the drain plug. It needs some fluid, it not sure what type goes into it.
  • Polidori
    • Jun 2017
    • 108
    • Lake Anna
    • Alexandria, VA
    • '05 SV211
    I believe that’s the fill port for the v-drive. Check page 149 in the owner’s manual.
    • beamons
      • Jun 2017
      • 378
      • Utah
      It is your V-Drive. The "Do not operate if light is still on over #### rpms" will stay light if it ever is too low.
      The year of your boat sometimes has issues with it leaking and a fairly easy fix if you are mechanically inclined. Follow this thread.
      https://www.planetnautique.com/vb5/f...-this-weekend=
      The fluid should be SAE-30 oil.
      • DJ Arwood
        • Jun 2018
        • 29
        • Mississippi
        I appreciate the responses. I'm new to the boat so I just want to make sure I check and maintain everything properly.
        • homer12
          • Feb 2016
          • 584
          • Indianapolis, IN
          • 2004 SV211 TE
          All good info so far, but I got to say is that water up to the middle of your v drive in the bilge?! That’s an issue there with you me bilge pumps not running and why do you have that much water in there?
          • beamons
            • Jun 2017
            • 378
            • Utah
            No dumb questions here. Just search the forums and you will likely find what you are looking for and learn a whole lot in the process of the search.
            Feel free to ask anything though if it doesn't make sense. Great people on here that have a wealth of knowledge and are very helpful. Like Homer.
            homer12 - I don't see the water. Is it a waterline that I just cant see that you are referencing?
            • DJ Arwood
              • Jun 2018
              • 29
              • Mississippi
              The water is puddled up around where the drain screws out. It's only a few mm deep.
              • homer12
                • Feb 2016
                • 584
                • Indianapolis, IN
                • 2004 SV211 TE
                Sorry! Nevermind, I was looking on my phone and didn't see it quite right. that small amount of water in the bilge looked a lot deeper to me. oops!
