I have a 2003 Nautique 196. A technician came out and said the Low Pressure Fuel Pump has bad pressure after running the boat at about 30 mph for about 2 minutes. The boat turns on and runs fine for a bit and then starves out after a bit and slows the boat down as it seems there is not enough fuel.
I replaced the low pressure fuel pump along and am having the same issue. The relay and fuse seem to be fine as the pump hums and vibrates a bit when the boat turns on. I am not sure where to go from here.
