Question for the experts:
Potential engine damage 2006 PCM engine was run without lake water recirculation. (My son forgot to open the valve last time it was run on land) Motor was run for 15-20 minutes. Was running at 3000rpm across lake and smelled somthing burning. Saw white smoke trailing from the back of the boat. Shut engine down immediately. Opened Engine compartment with fire extinguisher at the ready, but no smoke in engine compartment.
Note: engine temp guage never exeeded 175 degrees no engine overheat warning.
Engine compartment smelled like burning fiberglass. Removed engine cover and no burnt or melted wires gaskets were visible. Discovered closed water inlet valve. Opened valve.
Let engine cool for 1 hour. Engine restarted and idled fine. Concern about engine dammage returned to boat ramp at low rpm. Engine ran as ussual with no signs of misfire hesitation etc.
Concerend about very bad burnt fiberglass smell in the engine compartment. What parts should be inspected and or replaced after an issue like this? Will obviously replace impeller, as was run dry for 20 minutes. Engine Thermostat was replaced less than a year ago.
Did i get lucky or am i waiting for the other shoe to drop.
Any advice is welcome.
kzundel
kzundel
Keep an eye on her water temp being too LOW now, might need a new thermostat. Those often go bad after getting hotter than 215-225.. Have a great rest of the summer on her...and enjoy the "fresh air"!
