While removing a ballast pump, I accidently dropped my screwdriver on the starboard side of the motor. I’ve tried fishing around with my magnet and only found a washer and a nut. Any ideas on getting it out or if it will hurt anything floating around down there. This simple fix has turned into a pain in the ***. To top it off now my boat lift is slipping and want raise my boat.
You should be fine. After the first ride check again. I've done it myself and those things turn up.
What kind of lift?2018 200 Team H6
2009 196 Team ZR 409
2005 196 Limited ZR 375
2003 196 Limited Excalibur
1999 196 Masters Edition
1987 ProStar 190
You can always pull the divider between the motor and ballast tanks they just pop out then you have pretty good access to the motor. Whats going on with your ballast pump is it not emptying the tanks?
So when you push the button to fill or drain your getting 12.5v at the motor but the motor isn't running? Relays are under the steering wheel at the drivers feetOriginally posted by ROCKer View PostMy middle ballast pump is not working. It is getting 12.5 volts but will not turn on. I connected it to the starboard ballast connector and it ran fine. Where are the relays in this boat?
That’s correct on the voltage when I push the buttons. I’m trying to find the relays that actually sketch the polarity and allow the current to flow to the pumps. Someone told me they were in one of the rear storages. I’m going to track the wires coming to the pumps.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1Originally posted by ROCKer View PostWhile removing a ballast pump, I accidently dropped my screwdriver on the starboard side of the motor. I’ve tried fishing around with my magnet and only found a washer and a nut. Any ideas on getting it out or if it will hurt anything floating around down there. This simple fix has turned into a pain in the ***. To top it off now my boat lift is slipping and want raise my boat.
