DampRid Pails
  • GMLIII
    • May 2013
    • 2821
    DampRid Pails
    Has anyone used these DampRid pals in their boats? I was thinking of placing one in each rear stern locker to absorb the moisture in my G23; I do not use piggy back sacks in rear lockers so I have extra space in them. Didn't know if they were any good or a waste of money
    Click image for larger version  Name:	2018-05-29 13.24.13.jpg Views:	1 Size:	53.1 KB ID:	556757
  • charlesml3
    • Jan 2008
    • 2483
    • Lake Gaston, NC
    • 2022 G23
    Oh yea. DampRid is fantastic. There's even a "meter" on the side telling you when you have to replace them.
    I use three in the winter storage months. One up front, two in the back. I have little to no mildew to clean off in the spring.
    -Charles
    • GMLIII
      • May 2013
      • 2821
      -Charles
      Do you use during the season or just off season?
      • charlesml3
        • Jan 2008
        • 2483
        • Lake Gaston, NC
        • 2022 G23
        I only use it during the off-season. During the season, I live up at the lake full-time so I have ample opportunity to take the cover off and let the boat dry thoroughly during the week. I just don't get mildew during the summer.
        -Charles
        • DVskier
          • Sep 2014
          • 82
          • Seneca SC
          • 2004 Ski Nautique 196 LE
          I use Damp Rid during winter storage, my boat stays on the lift under a Sunbrella cover. I put a pail in front and one in rear seat area. No mildew at all. Damp Rid is inexpensive and works great.
          • scottb7
            • Aug 2011
            • 2198
            • Carson City, Nevada
            Maybe i should try it during off season. Do the pails just fill with water as it converts the moisture? Charles you use 3 of the big 4 pound pails? How full they get in off season?
            • charlesml3
              • Jan 2008
              • 2483
              • Lake Gaston, NC
              • 2022 G23
              Rarely more than 1/4 full. It really depends on how wet the winter is. This past one was really dry so I got very little in the buckets.
              -Charles
              • srock
                • Oct 2008
                • 1124
                I leave the lake house and often have to cover a little wet but with a Sunbrella cover. That situation along with Florida humidity seems like Damprid may not be the solution unless it releases mold control into the enclosed space. I was thinking of a small fan. Any confirmation for my situation would be great.
                • charlesml3
                  • Jan 2008
                  • 2483
                  • Lake Gaston, NC
                  • 2022 G23
                  Well the problem isn't mold. It's mildew. A lot of people think they're the same thing but that isn't true.
                  DampRid helps with this by absorbing the moisture. There are a lot of ways to absorb moisture. DampRid is a passive method. If you want an active method, then a dehumidifier would be appropriate.
                  • scottb7
                    • Aug 2011
                    • 2198
                    I don't, but if you have power to your boat while in storage then I highly recommend the davis air dryer.
                    https://smile.amazon.com/Davis-Instr...avis+air+dryer
                    • srock
                      • Oct 2008
                      • 1124
                      What I have seen in boats are more heater like the above than dehumidifier. Will that work well in Florida humidity?
                      • Evening Shade
                        • Apr 2015
                        • 1295
                        I use a fan and DampRid.
                        • wakerider107
                          • 271
                          • south
                          I used 4 damprid pails in florida. 2 in the rear lockers, cockpit, and bow compartment. I would wipe the boat dry after every use and wet lifevest were hung from board racks and boat was kept under the boat cover, but no canopy so it saw a lot of rain while covered.
                          The damprids kept mildew away, but I replaced them every couple weeks due to the high humidity there.
                          A fan would work great, but I'm always nervous running power on a dock and having an electrical device constantly running in the boat when i am not around.
                          2012 SANTE 230
                          • GMLIII
                            • May 2013
                            • 2821
                            With all the damp weather we have had in Virginia this summer and fall , I believe we are in store for a very damp winter. As I prepare for the winter lay-up period, I'm going to not only place a DampRid pal in each of the rear stern lockers, but I will place this high capacity DampRid Moisture Absorber in the bow of my boat. I had never seen one of these high capacity DampRid containers until I found them at Home Depot today( Cost $17.00). These are ideal for folks who keep their boats in their lift during winter lay-up or locations
                            where electrical power is not present to run a fan in your boat during the lay-up period.
                            Click image for larger version  Name:	damp.jpg Views:	1 Size:	64.2 KB ID:	570330
                            • PatM
                              • Jul 2013
                              • 25
                              • Little Alum Pond
                              • Brimfield, Ma
                              • 2018 Ski Nautque Team 200 CB
                              I use 5 of the small pals in my boat for off season storage. Always worked great.
