Fuel Pump Whining
  • rkilcoyne
    • Apr 2018
    • 21
    • Louisa, VA
    • 1995 Ski Nautique Signature Edition
    Fuel Pump Whining
    Getting my new "used" Nautique ready for the water. This boat has a 1995 GT-40 MFI engine. When I turn the key to the on position, I hear a whining sound for about 10 secs from the fuel pump. I'm assuming that's the low-pressure fuel pump priming. To give you an idea of how loud the whine is, I can certainly hear it when the engine cover is closed.
    My question is: Is that whining normal, or does it indicate there's a problem with the pump? If you have the same engine, do you hear that whining sound when you turn the key? When the boat starts it idles well, but after a minute or so, it starts to sound starved for fuel -- as if someone is pumping the throttle until it eventually stalls. Oh and you do hear the pump whining the whole time the engine is running.
    I suppose the other possibility is old/bad fuel... but that whining sound leads me to believe something else is going on.
    Thanks,
    Rick
  • charlesml3
    • Jan 2008
    • 2482
    • Lake Gaston, NC
    • 2022 G23
    Completely normal. In fact, if you DIDN'T hear that sound something would be wrong. I got so used to it on my 99 Air that I would intentionally listen for it when I turned the ignition on.
    -Charles
    • rkilcoyne
      • Apr 2018
      • 21
      • Louisa, VA
      Here’s a brief video of starting the engine with fuel pressure gauge attached to the fuel rail. Starts at 30psi and drops as RPMs go up. Also, how about that whirring sound? Cant be right.
      https://youtu.be/zd13cKndtbo
      • charlesml3
        • Jan 2008
        • 2482
        • Lake Gaston, NC
        • 2022 G23
        What do you mean by "can't be right?" It's in the video you posted. Starts at the 3 second mark.
        • rkilcoyne
          • Apr 2018
          • 21
          • Louisa, VA
          The sound he fuel pump is making, and the fact that when giving the boat throttle it drops and bogs down the a stall.
          • Infinity
            • Sep 2017
            • 730
            • Lake Norman - Denver, NC
            • 2014 SV244 w/ ZR409
            Have you checked fuel lines? Is it possible they are collapsing due to age and contributing to starving engine
            • Blamey
              • Sep 2015
              • 595
              • New York
              That does not sound right to me and you likely have a problem with your low pressure pump but it could also be several other issues including.
              - high pressure pump
              - bad relay
              - anti siphon valve
              - bad ecm
              You could take a flier on alow pressure pump and just get a new one. Or you can test the flow rate of your current pump by attaching it to a gas container.
              I have a new never used Low pressure pump which I bought last year when I was having issue, turned out to be battery related. It's for the GT40 with FCC so not sure it will work on yours.
              • rkilcoyne
                • Apr 2018
                • 21
                • Louisa, VA
                Thank Blamey -- really hoping it's not a bad ecm... I'm debating going with the LPP or just going full-bore with the FCC retro kit. Bad relay and anti-siphon valve components seem like a cheap check
                • Blamey
                  • Sep 2015
                  • 595
                  • New York
                  Also I believe that some lpp's have a screen in them, check the screen to make sure it isn't clogged.
                  I doubt it's the ecm. Lots more common issues to check.
                  Relays and anti-siphon are cheap. Always good to have spare relays.
                  Read the 'poor man's GT40 diagnostic' thread over on CorrectCraftFan.
                  Maybe even lost there, those guys are good at diagnosing engine issue.
                  • Skidave
                    • May 2005
                    • 698
                    • York, PA
                    Low pressure pumps fail frequently. Replace it and put an inline filter just before the low pressure pump.
                    Sent from my SM-J320V using Tapatalk
                    • kylem03
                      • Jan 2009
                      • 178
                      • Wisconsin
                      • 1983 Ski Nautique 2001 1994 Sport Nautique 1995 Super Sport Nautique 2007 Nautique 236
                      Before you replace anything pump wise, replace your fuel filter located between the gas tank and the low pressure pump. When I bought my ‘95 last year it had a persistent whine meaning the pump was starving for fuel. Similarly boggy on the mid-top end. Classic fuel starvation. The whine is happening because these pumps of that vintage (the high pressure pumps anyways) are lubricated by fuel. No fuel=no lube=fuel starvation= eventual pump failure. I replaced my filter 40 hours ago and no issues since.
                      Kyle
                      • rkilcoyne
                        • Apr 2018
                        • 21
                        • Louisa, VA
                        Thanks Kyle — seems like an easy place to start
                        • rkilcoyne
                          • Apr 2018
                          • 21
                          • Louisa, VA
                          kylem03 : Do you happen to know which inline filter you used?
                          • kylem03
                            • Jan 2009
                            • 178
                            • Wisconsin
                            https://www.nautiqueparts.com/produc...-pcm-r080024a/ this one but I bought a Napa equivalent. I will try and find a Napa number.
                            • kylem03
                              • Jan 2009
                              • 178
                              • Wisconsin
                              https://www.napaonline.com/en/p/FIL3482
