Was helping a friend Saturday night get his new to him, 2014 SV233 launched (with ZR409 engine). He did not realize it had a center drain plug and dropped it in the water. Soon as we saw bilge kick on a couple mins later, I opened back and saw water rushing in....he pulled vehicle back down and we got it on the trailer pretty quick. Water did get about 12" deep in bilge, just over v-drive connection.
I checked v-drive trans, red ATF fluid and no water in that....but I heard that the trans has a vent that water can get into it. What is best process to make sure there are no issues? Its the ZR409 engine with powerplus trans....so no dipstick and it has (according to my manual) the Mobiltrans 50 oil that is supposed to be "maintenance free", it does have the 2 square plugs you can remove and assume we need to remove and make sure fluid does not appear "milky" and if it does...what is exact process? Drain and re-fill....then do you run boat a little and repeat process again, or just repeat the process without running boat... I figure boat needs to run to make sure any milky fluid in lines comes back out so it can be sucked up on 2nd drain/re-fill, right?
After checking everything and draining last night, got boat running and it all appeared pretty good (ran fans in engine bay that night and sprayed with anti-corrosion spray on engine to help prevent issues).
1 other issue I noticed:
I have a 2014 SV244 with all electronic Livorsi control, but throttle is different on his boat. Its still a Livorsi throttle, BUT it has a cable (cable is blue and runs just over the v-drive in engine space). The throttle/cable seems pretty stiff on that boat, especially getting it into forward/reverse (could partly be that I am so used to my throttle action tho). Is this more normal for that throttle and maybe it just needs to be lubed and serviced to act smoother, or could it be that there is another issue. Boat had ECM read done on it when he bought it since they checked it out for him.....and it said 640hrs. Boat needs some love/TLC, but he got a good deal so putting some money into it is expected to bring it back to the BA boat it is.
Thanks
Thanks
