Hello All,
So I've posted a couple times about my Pro Air Nautique. Its a 2000 with the PCM 5.0 HO engine (275HP , Chevy 305, TBI). When I purchased it a month ago (not running), there were several major systems that needed overhall (mainly the fuel & cooling). Here is what we have replaced so far.
Fuel System
- Low Pressure Pump (Replaced) - https://www.nautiqueparts.com/produc...-pcm-ra080018/
- FCC (Fuel Control Cell) (Replaced) - https://www.nautiqueparts.com/produc...part-ra080031/
- Fuel line between Low Pressure Pump & FCC (Replaced) - https://www.nautiqueparts.com/produc...-pcm-ra085062/
- Both send & return fuel lines from the gas tank (Replaced)
- Injectors (Replaced) I also removed and cleaned the housing for the injectors
- Fuel Sending Unit from tank (Replaced) - https://www.nautiqueparts.com/produc...6-inches-long/
- Cleaned all connectors between the lines (Tank, TBI feed/return)
- Drained about 25 gallons of bad gas out of the tank, still had about 1-2 gallons of bad fuel that the pump I was using could not drain out. I then filled it up to the brim with 93 Octane fuel (30 Gallon Tank). This might be the issue still, so that's why it is in bold
Cooling System
- Thermostat Housing, Alarm (Replaced) - https://www.westmarine.com/buy/sierr...8?recordNum=18
- Water Circulating Pump, temp sensor (Replaced) - https://www.nautiqueparts.com/produc...ing-pump-5-7l/
- Raw Water Pump, Impeller (Replaced) - https://www.nautiqueparts.com/produc...-crank-driven/
- Cleaned water strainer
Cooling system seems to be flowing correctly after part swaps, don't believe this is the current issue)
Power
- Spark Plugs (Gapped & Replaced)
- Verified spark on all cables and checked distributor for wiring placement to the cylinders
Dash
- Temperature Sensor, Oil Pressure, Fuel Gauge, Battery (All working)
Oil & Filter Replaced
What I still need to replace (broken)
- RPM Gauge
- Speedometer
Current Issue:
So last weekend my friends and I finally took it out on the water after working on replacing the above parts. We still had issues with idling, so we routed the full send/return lines to a 5 gallon gas tank, and the motor had zero issue (drove up and down the creek at up to 40MPH (GPS phone). As soon as we attached the lines back to the tank, we ran into more idle and revving issues.
Yesterday, I replaced the raw water pump (old one was leaking), connected a hose up to it, and fired it up and ran perfectly idle for about 10 minutes (See Video Below). I noticed that the raw water pump was wobbling slightly, so I stopped the motor to tighten the bolts. When I went to fire it up again, the engine would not fire up properly (tried about a dozen times with various positions of the throttle)
Sorry for the long post, but I wanted to give as much detail as possible. What do you guys think is the issue here?
https://youtu.be/y8xgo6rs6rk
Fuel System
Cooling System
Power
Dash
- RPM Gauge
- Speedometer
Current Issue:
