Wakesurf Edge
  • srock
    • Oct 2008
    • 1100
    Wakesurf Edge
    Will a wakesurf edge fit onto a 2009 230 hull at the proper height?
  • Nautiquehunter
    • Jun 2008
    • 2099
    I just make then out of aluminum bar and glass handling suction cups from Amazon. Works great on my 210 I have made them for a few friends with different brand boats works great on all of them . I don't see why it wouldn't work on a 230.
    • fb_rider
      • Jul 2010
      • 88
      • Westminster, MD
      • 2004 Super Air Nautique TE
      I haven't had much success using one of these on my 210. I don't remember the brand, but it's basically made from a harbor freight suction cup and a cutting board. Any special tricks I'm not thinking of?
      2004 Super Air Nautique 210 Team Edition
      1994 Ski Nautique (sold)
      1979 Ski Nautique (sold)
      • Nautique Fan
        • May 2016
        • 136
        • Utah
        • 2007 SANTE 236 ZR6
        Here are some pics of the one I made and where I place it on my 2007 236.
ID:	550743Click image for larger version
        • srock
          • Oct 2008
          • 1100
          If it works at the height in the photo I am good to go. I didn't know if the right spot would fall lower on the hull where it would not fit. Started off thinking I would make one but for $300 and being busy I am going to send my money off.
          • Nautique Fan
            • May 2016
            • 136
            • Utah
            The one in my photo sits just below the water line with my stock ballast full. I don't have any additional weight, so if you do, that would only push it farther down.
            • srock
              • Oct 2008
              • 1100
              Perfect, thanks.
              • Infinity
                • Sep 2017
                • 730
                • Lake Norman - Denver, NC
                • 2014 SV244 w/ ZR409
                srock Check out Nauticurl.com This is the one I use on my boat, is cheaper than $300 (think $230), very well built and the best customer service you can ask for. When secured right, it does not come off boat.
                FYI...do NOT tie suck gate to boat since if it comes off, it can bang into the gelcoat, swimdeck, etc. I tie to a boat fender. Most of them now (including Nauticurl) float tho so not something you gotta worry about, just saying in case you go homemade
                • Rockymtnsurfer
                  • Nov 2017
                  • 404
                  • Steamboat Springs Colorado
                  • 2003 210 SANTE
                  Get White too....if you get black or dark color......hard to see it floating if it comes off......was my lesson learned
                  • srock
                    • Oct 2008
                    • 1100
                    Thought about that right away and i have a small orange float that will work perfectly. Thanks.
