Repair Starboard Side Keypad? - 2000 Pro Air Nautique
  • comanche344
    • Mar 2018
    • 30
    • TEXAS
    • 2000 Pro Air Nautique, PCM 5.0 HO 275HP, Chevy 305
    So I found out my starboard side keypad on my 2000 Pro Air Nautique is not working. Found this link for the part, $400 bucks. Ouch!
    https://www.nautiqueparts.com/produc...-in-black-now/
    Anyone on the forum been able to repair these? I realize they are sealed units, but are the electronics complicated if it could be opened, resealed?
  • xlair
    • 694
    • Wisconsin
    I don’t think anyone has repaired these, to my knowledge.
    2001 Pro Air Nautique
    • Blamey
      • Sep 2015
      • 595
      • New York
      You can used the site coupon code for a 10% discount. PND.
      You can try open it up and see if you can figure it out but I'd probably just spend the money on a new part.
      • comanche344
        • Mar 2018
        • 30
        • TEXAS
        Yeah I think I'm just gonna have to bite the bullet and order it. Thanks guys for the help.
        Sent from my Pixel 2 XL using Tapatalk
        • 2000superdare
          • May 2011
          • 72
          • long island
          • 2000 super air
          I wish they could be opened and repaired i've replaced my port side pad 3x in the past 7 years. I now leave it unbolted and when the boat goes on the trailer it goes in a bag of rice. The way the dash is designed they seem to go bad due to sitting in a puddle for extended periods of time like after you wash it. Now mine get removed and placed in a sealed bag with rice and stored in a dry place.
          • comanche344
            • Mar 2018
            • 30
            • TEXAS
            Thanks for the tip, that's probably what I'm going to do. These things are too expensive to fail all the time.
            • 2001SAN
              • Apr 2012
              • 203
              • Ireland
              • 2001 Super Air Nautique 210, 1989 Fairline Corniche 31
              +1 on removal. I remove both every year and so far so good.
              D.
              • comanche344
                • Mar 2018
                • 30
                • TEXAS
                Last week I found a post where someone had converted to analog switches. Can anyone help me find this post? I've searched keypad, toggle, starboard. Can't seem to find it.
                • scottb7
                  • Aug 2011
                  • 2198
                  • Carson City, Nevada
                  If it was me I would take the sob apart before buying a new one...But that is just me. What I would do is use a soldering iron with a cutting tip and unseal from the back.
                  I bet it will be real simple inside. But that may or may not mean it is repairable...But I bet you can fix it.
                  • 2000superdare
                    • May 2011
                    • 72
                    • long island
                    • 2000 super air
                    only 3 wires come out of it, it sends signals to the computer below, problem is once you break the epoxy seal water can easily get in there. Water is a conductor, overtime you push a button its like holding it down, you will have problems with starter staying engaged or the horn blowing......ask me how I know. There was a right up on here at one time on how to bypass all of it.
