I am looking for a points distributor for my ford 302 reverse rotation and am having a hard time locating one. Does anyone have any ideas??
I think I was incorrect in the above post. That applies to some Chryslers & Chevys. The 302/ 351 Fords use a regular chain drive for the cam with RH rotation. The dizzy drive gear on the camshaft is cut "backwards" on the reverse rotation cam causing the dizzy and oil pump to rotate in the normal direction which I think is CCW. You only need to change the drive gear on the dizzy shaft.
I have a distributor that was with the parts from the 302 I got with the boat and it appears to be counter clockwise rotation and it has a number of 64025 stamped on it. When I google that it, the only thing that comes up is a distributor for mercruiser. Not sure of this will work or ???
Is it better to go with an electronic distributor like a Mallory??
I have. The gear is cut backward. I talked with the engine manufacturaer to make sure I had the correct engine. The gear should be cut right to left. I have a new gear on the way.
I should have been this one:
MAL-YLM512DV
Distributor, Ford V8 302 M.B.I. Marine, Reverse
Description: Distributor, Ford V8 302 M.B.I. Marine, Reverse
Everything else was the same but the cut of the gear.
