Originally posted by DaveNH
View Post
If you really dislike the 5 minutes, you can buy/make a quick drain setup by putting fittings with shutoff valves on all the drain points. Then you can just open them quickly without any tools, close them up, and run a/f through the system. I had these on my old boat and I could go winterize the boat with only a 5/16 nut driver (to take the heater hose off.)
I'm with you on that, I have petcocks on my drains as well. The 5 minutes was generous, assuming I'd get the usual 3 texts from my kids while I was trying to do it!
The other, very real benefit is that you can probe the drains to let any silt flow out that might be accumulating in the block, depends on where you boat as to how much gets in. And, you tend to flush the scale out of the risers as they drain.
I did this with the heater core so it can be easily maintained. Thanks for the info guysOriginally posted by functionoverfashion View Post
