I plan to use the boat over the winter months so need to come up with a quick winterise method. As I have the closed cooling zr6, I’m wondering if I can simply run antifreeze through the heat exchanger/manifold via the bucket method. I’ve used this method on prior boats, most recently a raw water cooled indmar 350tbi. I have created my version of a fake a lake so can close off the raw water hull intake and have a hose routed to a 25ltr drum so simple enough to draw antifreeze in and I can catch it in the exhaust via another bucket.
Is there a thermostat in the raw water cooling side, Ie will I have run up to temperature first, or simply a case of drawing the antifreeze through and the manifolds, exchanger, filter and transmission cooler then protected.
The ballast tanks I can easily empty so my concern is with the engine alone.
Thanks!
Thanks!
