I bought a 2001 Sport/Air Nautique W/ PCM Apex 320hp Multi-Port EFI back in April with 660hrs. on it. I've put 70hrs on it since then. Since purchasing the boat has ran flawlessly. You can tell by the condition it has been meticulously maintained from front to back. I check fluids before every use and empty water strainer also. Temp gauge never goes above 165°F-170°F. Oil pressure around 20PSI in neutral, 40PSI when RPM's increased. No leaks everything appers to be pristine.
I was out over the weekend and noticed the boat would idle in gear while the throttle was in neutral. At first I though I was losing my mind but I left the boat in neutral and checked the stuffing box, the shaft was indeed turning slowly. When you first start the boat it wont be in gear, if you engage forward and then back to neutral it will still idle in gear. You have to kill the boat and start it back up to be in neutral again.
I have no issues going into forward gear, no isses going into reverse gear. Everything sounds solid, no weird sounds or slippng.
Anybody had the same issue? Completely out of the blue. I am the only driver and have ran this thing atleast a few hours every weekend since I had it.
