This one has me, and my friends. 2003 SN with PCM GM. I replaced the impeller because the boat was overheating. The used impeller was bad, but I have seen worse. I pulled the pump housing out of the boat, but kept the mounting bracket attached (so it would not get put backwards).
With the new impeller in, I ran the boat for about 15 minutes and the temp was steady at 159. Today, I pull a skier 6 passes. When I get in the water for my set, the boat starts to overheat.
We pulled every hose and found no blockage. With the discharge hose off of the impeller pump, there is only a small amount of water coming out of the impeller pump. I double checked the new impeller and it is fine. The pump housing looks fine.
My dealer said that he has seen this before, the pump looks fine, but after replacing with a new one the problem went away. I just can't seam to grasp how it could be bad. There are no moving parts to speak of.
Anyone have ideas?
Anyone have ideas?
