Can someone tell me what model/type works better with the surf select feature on the G23 2017. Thanks,
I just use the Pebble Classic. They're plenty cheap on eBay and work just fine. I believe one of the other models (maybe the Pebble Time) adds Ballast Shift to the watch, but that seems rather useless to me.
-Charles
I ordered a classic off ebay. It should be in this week. If I get it before Thursday I'll report on connectivity, although I won't be able to test in water. I'll be on vaca the following week and away from my rig, but I'll be all over it as soon as I get back.Originally posted by charlesml3 View Post
I wish someone with a 2018 and Surf Select would confirm (or deny) that the Pebble works. So far, nobody has said anything.
-Charles
I have ordered a couple my self. I will do the same and comeback with the report. there is a lot of people complaining about the connectivity so i think we need to put it to rest. Either works as stated or its a complete flawed system Wait for an update!!
That'll be great. If you can get it to pair, you should be fine. Heck, you can go look on the boat and see if "Pair with Pebble" is even an option in the LINC.Originally posted by G_WaTT View Post
-Charles
I checked my LINC yesterday and it does give you the option to pair it with the pebble watch. I have ordered a couple and will try to sic them ASAP. I will keep you guys posted.
Awesome, thanks man. Funny how Nautique doesn't even mention it anymore. I keep hearing about how they're developing something to replace the Pebble, but there has been nothing solid on that.Originally posted by G23 GonZaga View PostI checked my LINC yesterday and it does give you the option to pair it with the pebble watch. I have ordered a couple and will try to sic them ASAP. I will keep you guys posted.
-Charles
Good idea to get a couple of them because at least one will need up on the bottom of the lakeOriginally posted by G23 GonZaga View PostI checked my LINC yesterday and it does give you the option to pair it with the pebble watch. I have ordered a couple and will try to sic them ASAP. I will keep you guys posted.
Luckily I bought 2 because 1 ended up at the bottom of our lake. I think it came off when I was wakeboarding and crashed hard. So I have a second one and no more wakeboarding with it on.
2016 G23
I have a 17’ GS20 and they, Nautique, had to send me a 2.0 module as it was installed with a version 1. Unfortunately with Hurricane Harvey impact I havent been able to swap out and see if connects, I was near giving up until someone from Nautique rang me up ...
Installed new module his weekend that nautique sent me and my pebble time worked flawless. First boat and every instance of issue nautique has taken care of
The reason they went with Pebble was because the controls were physical button controls. Apple touch screen watch in the water has no prayer of functioning.Originally posted by mattkalin View Post
