2012 230
Noticed a lot of water in the bilge, first thought was thru hull at the drive shaft but not seeing much leaking there. So hooked it up to the hose in the garage and noticed lot of water along the surpentine belt, thought it might be a bad clamp/hose connection, tightened all of them but still lots of water. Unfortunately with the belt spinning, having a hard time localizing the source. Wondering if anyones had a similar experience? Is there is a gasket on the circulation or raw pumps I should be checking? Or should I just go right to replacing the raw pumps? Any thoughts or pointers would be appreciated, hope everyone's having a better labor day.
