Need new V drive where to find one need help!
  • Zpenter
    • Feb 2014
    • 17
    • Arkansas
    • All of them!
    I have a Walter v drive rv-26d in my 2003 San 210 well it died after 900+hrs.some of you guys that have been in my shoes did you go back with the same V drive "Walter" or change brands if possible plus I need to find one any help would be great thanks guys and gals!!
  • Blamey
    • Sep 2015
    • 595
    • New York
    Died how? I think you can ship it to Walter and they will be able to fix it.
    Not sure about changing to a different brands.
    • nukemustang
      • Sep 2014
      • 410
      • Summerville, SC
      • Current Boat: 2018 GS20
      https://www.planetnautique.com/vb5/f...rive-tear-down
      Not mine, but I remember reading this. It was shipped back.
      tim
      • t.franscioni
        • Jun 2014
        • 715
        • United States
        • 2002 SANTE
        I sent mine back to Walter in NJ a few years ago. They can repair and if unable will sell
        you a brand new unit. I'd stick with Walter so you don't have to get into modifying the mounts or worry about everything lining up with your prop drive shaft.
        • Zpenter
          • Feb 2014
          • 17
          • Arkansas
          • All of them!
          If you don't mind how much did it run you having them rebuild your v drive?
          • t.franscioni
            • Jun 2014
            • 715
            • United States
            • 2002 SANTE
            Pretty expensive....$1200 I want to say? It needed a new copper cooling line, new bottom gasket and a new top cap and oil pump rebuilt I believe . The main housing and gears were okay. If either of those two major items fail then your looking at a new unit as I recall. New unit was like $3000 or something I can't recall for sure. Give em a call they were very nice and helpful over the phone.
            • Zpenter
              • Feb 2014
              • 17
              • Arkansas
              • All of them!
              Yep new v drive cost me $3400 and mine could not be rebuilt bc the bearing got into the gears and messed them up
              rebuilt one if gears are not messed up will run you $1700
              • wakejunky
                • 679
                • Ca
                • 2003 SAN
                Begs to be asked...Why would the v-drive go out? Things like this make me really nervous and anything I can do to help prevent it and I on it.
                Also, if you do need a rebuild, could they change the rotation for the pre-2006 years?
                • Blamey
                  • Sep 2015
                  • 595
                  • New York
                  Check and change your oil.
