I have not checked my water stainer for debris yet, but it seems like my engine water temp has been creeping up somewhat. On Tue it was running around 173 degrees. Isn't the normal engine temp on these H6 engines around 160-165?
Ours seems to run about 160-165. (2017 G23). If I am towing and full of ballast for a long time it will creep to 170, usually wake surfing but its usually around 160-165. This was yesterday. It was 100 degrees out all day (ultra warm water temps) and at the end of the session on the cruise back to the dock.
Mine is 163-165 as well.Please do not PM me directly asking for advice on how to repair your boat. While I would love to help everyone, I simply do not have time to respond to all of the inquiries. Please post your questions on the forum, so that all of our members have a chance to answer.
Does the H6 have a fresh water or raw water (closed vs. open) cooling system? My ZR4 with raw water cooling system operates at 163-165*. My ZR450 with fresh water cooling system would definitely creep up over 170* when the engine was pushed hard. If you push a fresh water cooled engine hard with lots of ballast you will eventually exceed the cooling capacity of the heat exchanger and the temp will start to creep up.2007 Malibu Wakesetter 23 LSV, 1995 Cobalt 200
Even with closed cooling you should never see the temps creep real high. Eventually it goes to water which is a great place to dump heat.Originally posted by Evening Shade View PostDoes the H6 have a fresh water or raw water (closed vs. open) cooling system? My ZR4 with raw water cooling system operates at 163-165*. My ZR450 with fresh water cooling system would definitely creep up over 170* when the engine was pushed hard. If you push a fresh water cooled engine hard with lots of ballast you will eventually exceed the cooling capacity of the heat exchanger and the temp will start to creep up.
Thanks for the help. I will check water strainer first for issues/debris . If still high I may be back with questions
