I have a 2005 SANTE. I am wondering what settings others use for the keel offset. The prop/rudder are about 14 inches below the hull, so that would be a -1.2 ft setting for the Keel Offset. I would rather know how much clearance I have below my prop, rather than how deep it is from the hull. What is everyone else using?
Tags: None
You can look in your manual to see what your boat drafts unweighted. That would be waterline to lowest point of running gear
Because the depth sensor is sitting on the bottom of the hull, I don't think using the boat draft would be a good idea for the keel offset. The sensor would already be sitting 1-2 feet below the water line, so using -2.3 feet (28" draft according to the manual) for the keel offset could display more clearance than I actually have.
