Replacing the Stuffing Box with a dripless (PSS) system
  • EchoLodge
    • Jan 2004
    • 616
    • Huntington Beach, CA
    • 99 Super Sport
    My 1990 SN has 800 hours on it and as of last year, I had not done a thing to the stuffing box. When I noticed it really starting to leak, I adjusted the stuffing box to slow the water down (2 - 4 drips a minute per nautique). I was going to replace the cotton string with the synthetic but was wondering if I should replace the stuffing box with a dripless system. Is the $200 worth the cost?
    sigpic
  • tryan
    • Nov 2003
    • 267
    • gatlinburg tn
    200 bucks for a dripless seal or a buck for some flax packing.
    if you store the boat in the water , go for the dripless. if you don't, i could think of a few more things i could blow 200 bucks on.
    red right return
    • skinautique
      • 1749
      • Colorado
      I would just replace the packing. The true benefit to dripless is on the Vdrives because it is such a pain to get at the packing. With your boat, it is a piece of cake to get at it.
      • EchoLodge
        • Jan 2004
        • 616
        • 99 Super Sport
        Thanks for confirming my thoughts.....
        sigpic
        • M3Fan
          • 1034
          I thought of doing this when I first got the boat, but I'd rather spend the cash on several more important items before that.
          2000 Ski Nautique GT-40
          2016 SN 200 H5
          www.Fifteenoff.com
          • EchoLodge
            • Jan 2004
            • 616
            • 99 Super Sport
            Shower time!
            Maybe I will install a shower, family loves the heater I put in this season!
            sigpic
            • EchoLodge
              • Jan 2004
              • 616
              • 99 Super Sport
              Stuffing Box Fixed!
              Piece of cake... 10 minutes and when using the synthetic string.... No more leaks.
              sigpic
              • tryan
                • Nov 2003
                • 267
                • gatlinburg tn
                do you have to retighten the synthetic packing after you run it in?
                you should have a drop a couple times a minute with the organic string and none when the shaft is not spinning. the water is supposed to lubricate the shaft.
                red right return
                • EchoLodge
                  • Jan 2004
                  • 616
                  • 99 Super Sport
                  Per my mechanic... The teflon in the packing does not need the water lube that the rope does. I put 2 hrs on the boat after I installed it and still no leak.
                  sigpic
                  • tryan
                    • Nov 2003
                    • 267
                    • gatlinburg tn
                    good to know. thanks.
                    red right return
