Adding New Internal Ballast Pumps to 2004 SAN210 - Recommendations?
  • SCNautique210SAN
    • Mar 2011
    • 194
    • SoCal
    • 13 G23 04 SAN 210TE 92 Sport Nautique
    Hey Guys,
    Looking into replacing the internal ballast pumps on my 2004 super air 210. Anybody used the Rule Tournament 1100GPH pumps? https://www.wakemakers.com/rule-aerator-short-ballast-pump-1100.html
    Right now I'm running the Tsunami 1200GPH, but I run electronic actuators that open and close the valves which restrict the flow a bit and I don't think the Tsunamis have the torque to pump up tanks so I'm looking into more powerful pumps. And the original pumps would fill quicker.
    Anyone have any other recommendations for pumps?
  • prowakeskater
    • Aug 2016
    • 59
    • florida
    • 03 SANTE
    what valves are they?
    • XBIGPUN66
      • Oct 2012
      • 474
      • Lake Mendota
      • WI
      We replaced the factory pumps with the jabsco two way pumps
      Sent from my SAMSUNG-SM-G930A using Tapatalk
      Ian S
      • SCNautique210SAN
        • Mar 2011
        • 194
        • SoCal
        I bought three of these for the whole system: http://www.ebay.com/itm/DC-24V-1-2-B...item4d460dbdab. The pictures don't show the inside but it's pretty restricted.
        But I just purchased these as a replacement and am going to start here: https://www.amazon.com/gp/product/B0716KHT67/. They're 3/4" Full Bore instead. Will maintain the 1200GPH tsunami pumps with these new ones and see how it does. Taking it back out next weekend so I'll update how it goes.
        Last edited by SCNautique210SAN; 06-06-2017, 10:25 PM. Reason: Updated the link to the replacement valves that I used. Needed to be naturally closed ball valves so that once power is cut, they shut.
        • SCNautique210SAN
          • Mar 2011
          • 194
          • SoCal
          Still could use some recommendations on pumps that have a higher flow than the tsunamis though!
          • bowvan
            • Aug 2005
            • 100
            • sacramento
            I replaced the fill pumps with the same pumps that are used as empty pumps, in my 04. Rule 1100's I think. You will need to increase the intake hose from the through hull to 1". I also am using 1" electric valves. I don't remember what brand valves I used (its been a while), but they didn't effect my flow rates. You have to get creative with adapting the hose to the pumps. I think I just slipped the hose right over the threaded intake and secured it with hose clamps. I have all three tanks plumbed the same way. Its been 10 plus years and other than replacing 1 or 2 pumps along the way, everything still works flawlessly.
            • prowakeskater
              • Aug 2016
              • 59
              • florida
              • 03 SANTE
              yeah you need to replace the valves you have with those ball valves
              i have mine threaded directly on the output of the pumps for the rear
              cheers
              • SCNautique210SAN
                • Mar 2011
                • 194
                • SoCal
                cheers
                Thanks prowakeskater . I have them set up before the pumps in the rear. Just swapped them out with these: https://www.amazon.com/gp/product/B0716KHT67/. But I don't think having them in front of the pumps will matter now (with the solenoids I think it definitely did)? They're full bore now though so the ball is as big as the hoses that feed into it.
                bowvan Are the hull intakes 1" or 3/4" on yours? Probably a good idea to swap out with 1" if I really want to get some flow going.
                • bowvan
                  • Aug 2005
                  • 100
                  • sacramento
                  I'm not sure, but I think I remember the inside diameter being 3/4". The 1" hose I used slipped over the top of it, just like the intake to the pump.
                  • prowakeskater
                    • Aug 2016
                    • 59
                    • florida
                    • 03 SANTE
                    yeah theyre 3/4. I was going to go with 1200gph pumps but would have to change everything including 1" thru, 1" hose, and 1" ball valves when i already had 3/4.
                    OP- watch those ball valves so that they never sit in water. I had to replace mine because they got damaged by bilge water, which is why i put them on the top/output of the pumps, out of any standing water
                    cheers
                    • SCNautique210SAN
                      • Mar 2011
                      • 194
                      • SoCal
                      Thanks guys. I'll let you know how it works! Headed out this weekend
